Ok, i know the stock w/g is supposed to be 15PSI, and that they used a boost solenoid for the ECM to control the w/g, but if you were to run the stock w/g with only a vacuumn line going from the comp housing to the nipple on the w/g would you still get the 15PSI or woudl it be higher or lower?
Also if it is still 15PSI is there anyway to lower it? and if so by how much, like could it be lowered to around 8-10 PSI?
Thanks for the help.
