STOCK WASTEGATE!
BOOSTED92TY
Anyone have a pic of how the stock piece of junk wastegate is setup on your truck my truck is spooling kinda slow i think this could be the prob...did a search thats what gave me this conclusion i just need a PIC to check and see if mine is set up correctly! probably not just like everything else on the truck! :eek:
jwaller
Evil Genius/SyTy Guru
do you mean how the rod is connected to the arm or how the wg solinoid is routed to the comp cover and to the wg actuator?
jwaller
this is a pte turbo but the wg setup is the same. you want the eye of the wg arm to just about cover 7/8 of the pin when looking at it froma side view. thghter to run more base boost and looser for less. stock is 8psi.
