Strange clicking noise.
wheels
Hey guys, need some help. Lately i have been hearing a clicking noise from what seems like under the dash. When at idle it is a constant click, but when given a little gas, even in park, it sounds like a zip-tie is being pulled and goes away at higher rpms. When in the engine bay i hear the same thing. Move the throttle a little bit and it makes the same noise. I checked the fuel rail, it doesnt really feel like it should be making that noise, it doesnt change when i press on it. It is plenty loud enough to hear with the hood down. Any ideas?
SeattleSy#1255
Category 5 Conservative
Re: Strange clicking noise.
vacuum leak perhaps? If you haven't already, replace all the stock vacuum lines. Can't hurt doing anyway if you havn't done so already.
jjorgensen52
NHSTE - I'm the only one!
sounds only somewhat pertinent, but my moms suburban feeds back through the speakers with rpm .... but this wouldn't account for underhood noise
blk00z28
Forced to by choice
Can you narrow down where the sound is coming from at all? Like left side, right, back of the motor, front.. ?
Robert Lone
MUTANT
Small exhaust leak? Plug wire arcing? Lifter raising hell? Rocker arm out of adjustment?
SY2932
Administrator
MikeRenz said:
sounds like injector tick to me
Ditto. Get the truck up in the air and check the fuel lines near the bellhousing on the transmission. If they are touching sheetmetal, that is the source of your clicking. This is a common problem for trucks that have had the motors replaced. Hard line gets bent and makes contact with something. The injector "click" then gets transmitted to whatever it is touching. Fixed this problem myself on a owner's truck (syclone) a few years ago.
wheels
Yeah my first thought was the fuel rail or injectors. I'll check it out. Thanks guys.
