Strange coolant/oil issue
stuckinUT
In other threads I have detailed how it appears I blew a head gasket and drove with coolant in the oil for about 20 miles, so I am going to pull the motor and either rebuild this one, or replace it completely to save time.
Well today I drained the oil and topped off the coolant so I could drive it to my friends shop where we are going to tear into it (it is a 35 mile drive, so I wanted fresh oil and a full radiator just in case). While the oil was draining I started to fill the radiator and noticed a sound like the oil was draining faster. I stuck my head under there and sure enough, as I add coolant to the radiator, coolant immediately starts draining out the oil pan! WTF? What would cause that?
Can just a blown head gasket cause enough flow of coolant into the oil system to cause that, or am I looking at a major crack in the block or head?
I also noticed coolant sitting on the drivers side lower intake manifold where it meets the head that I hadn't noticed before, and when I squeeze the radiator hose I can see the coolant and air bubbles forced out in the front driver side where the lower intake meets the head. If the lower intake to head gasket is blown there would coolant be able to get into the oil? And enough to cause the coolant to flow straight through as described above?
Sorry for the long post, I was just curious what would cause a coolant leak enough to drain straight through into the oil like that. If I could just replace the intake manifold gaskets and be able to drive it occasionally until I can afford a proper rebuild in the spring/early summer that would be awesome. I would like to be able to drive it occasionally until I can go forged bottom end, instead of having it dismantled in my buddy's shop waiting for me to save up enough scratch to rebuild/replace it.
Thanks in advance guys, let me know what you think.
stuckinUT
Re: Strange coolant/oil issue
Thanks Dave.
I actually pulled the plugs last weekend, and they were dry, looked really good actually. They all looked the same, none cleaner than the others and so forth. It ran OK before it started eating coolant, just acted like it had a bad vacuum leak. Wouldn't a bad intake gasket possibly cause that too? I can do the intake at my house. I just got fed-up with it when coolant showed up in the oil, so I called my buddy and asked if we could do a motor for my truck at his shop, impulse decision I guess.
I will pull the intake this week. What specifically should I be looking for with the intake off for a head gasket issue?
Thanks!
stuckinUT
So I finally got the time to pull my intake off and see what I could find. The intake gaskets had failed on both sides at the top and bottom of the coolant passages. Now I just have to put it back together. And on the note of putting it back together, I managed to break the 90 degree coolant fitting at the front of the lower intake manifold for the turbo coolant return line, it was corroded as hell. As well as snap a vacuum fitting off the EVRV solenoid. So if anyone has these laying around they want to get rid of cheap that would be great.
As far as the 90 degree fitting and EVRV solenoid, are they dealer only items? The parts guy at the closest parts store was clueless and had no idea what a EVRV solenoid was. Could it be called by a different name and what does it do exactly (excuse my ignorance)? Thanks all!
i think i have that solenoid thing in my old parts chest. ill look and let you know. And ill look for that 90 deg fitting too.
stuckinUT
I actually was able to find that 90 degree fitting for $4. I realized after I made this post that the EVRV solenoid is the EGR solenoid. When I broke it I just grabbed the manual to see what it was and that's what the manual called it. I had never heard it called a EVRV solenoid before, but looking at where the vacuum lines went from it I realized what it was. I feel a little dumb now. It was relatively cheap so I just got a new one. So I am set to reassemble everything now. Thanks though.
