jharrison
When the truck sits for a while, maybe a month or so, and I fire it up I hear what is best described as a playing card on bicycle spokes. If I stay parked and go through the gears a few times it goes away, or if I just start driving it goes away. The noise seems to eminate from the transmission / torque converter area. From under the hood the noise is the loudest from the drivers side where you can see the trans, from under the truck it seems to be around the bell housing / inspection cover area.
Everything is new, SFI RPM flywheel w/ ARP hardware, RPM 9/11" torque converter, and the whole motor only has 22 miles on it. It runs and drives fine, shifts correctly and firmly. It's just this clicking noise that is there when you fire it up that is not coming from the motor, fuel injectors, or turbo, but clicks faster or slower with RPM.
Is my brand new torque converter going out?
