Strange O2 sensor and EGT guage problem
OK, heres the deal, when i send power to my EGT guage that ghas the probe welded in the DP right behind the stock O2 sensor the O2 MV im watching in the ALDL stream go to 1101 and the turck quickly goes to LEAN on my WB readout and dies, when i turn off the EGT guage the truck and O2 function properly.
Now i recently removed the engine to install some new solid motor mounts and frame pads and a new TCI 2800 converter, and i cleaned up the frame rails, installed a ZQ8 steering box and borgeson shaft and did alittle taping on some wires and replaced both battery cables.
Anyways the EGT was hooked and powqered up the same way before the engine was oput and i didnt have this problem, this problem showed up a few days after i had it running with the engine back in.
Now if i take a wire and clip one end to the outside of the probe and the other end to the neg side of the battery the O2 starts to work properly.
Do you think that this means my EGT guage and probe is bad? Ive never seen or heard of this problem before and any help is appreciated.
Thanks
Bill Z
Re: Strange O2 sensor and EGT guage problem
Mike,
I know you added several new grounds. Could have you removed the ground the EGT needed? Sounds like you replaced the ground and it worked.
well i called up Autometer and the tech guy said my EGT probe was bad, and that that was causing the interferance with the O2 sensor. So now i have to spend 50 bucks for a new probe.
