jharrison
Occasionally, my Sy acts like the timing wire below the dash is disconnected. Check gauges light and engine light come on, timing drops to 0 degrees, and I can't connect to the PCM with my laptop (it says there's no sync and cannot find PCM). Here's the catch, I have traced the timing wire from the PCM to the ignition module, and it's fine. It isn't broken or shorted, and I have connectivity from the PCM connector to the ignition module connector no matter how I jostle the wire, loom or cable bundle.
What I don't understand is that magically without doing anything the problem just goes away, timing comes back, and I can connect with my laptop. I can't associate the problem with temperature or drive cycle, it happens randomly, and when it happens nothing I do makes it go away.
Mike Lee thought it might be PROM related, like the chip not being seated correctly, but I have swapped from an RPM 16 bin chip with carrier, to a Hood chip without a carrier, and the problem still comes and goes.
I'm leaning toward a bad PCM or ESC module, but I have been told that if either of those were bad the truck would be totally dead, no start, nothing. Everything in this truck has less than 20 miles on it, motor, turbo, and all sensors. My sig has all the info for my truck.
Any ideas? :banghead:
