sy2206
OK, just got my new t/c, tranny, and t-case installed a couple nights ago. Took it for a spin, everything drove great, put 70 miles on it that night. Took it out the day after for a 25 mile cruise, everything was perfect.
I put a tranny cooler in it today, the same one everyone uses, the B&M. Now, took it out tonight for a spin and something is wrong. There is a clunking type vibration coming from under. Not all the time, goes away when you get on the gas, but if I'm cruising, and pull up to a light, as soon as I get out of the throttle, the vibration starts as I'm coasting to a stop. You can feel it in the shifter, feel it in the floor, and can hear it aswell. Here's the things I already checked:
tranny is full of fluid
propshaft bolts are tight
shifter brackets and cable is tight
torque arm is tight
everything looks good from under the truck
I did replace the mount between the crossmember and the tranny/t-case when i had it all apart. I also noticed the new one was a little taller, I'm sure from being less worn. When I was under the truck tonight, it looked like the t-case might be hitting the floor boards, like that mount's to tall. And this kind of makes sense because when you get on the gas, the motor torques to the right, and will torque the t-case down away from the floor, as soon as you let off, and the motor torques back, now the t-case hits and causes the vibration. What do you think?
But, this doesn't explain why I never felt it the first 95 miles I drove. I know the new mount is correct, because the part numbers were the same. And my motor has 2 torque straps, so there is almost no movement of the motor when you rev it up. So I'm not really sure.
I can't imagine for some reason the tranny cooler would cause this. I checked all the lines and connections. No leaks, nothing's kinked. Any ideas guys?
torque arm is tight
