Stretching the stock ECM
TurboTony
Well everyone, it's finally alive!!!
For those of you not in the know I'm working on a new combo that will hopefully test the limits of the stock ecm without exceding them.
Here is the combo in a nutshell.
Stock ecm with modded drivers for p/h injectors
Stock block buildup, typical parts, trw's eagles, etc
Comp cam 09-412-8
Stock ported vortec heads
PT 72 turbo 8)
KB a/a intercooler with custom piping
Stock manifolds, ceramic coated
Custom PTE style d/p
PTE exhaust housing
3500 ish 9/11 convertor
Built tranny
Sumped fuel tank
External aeromotive A1000 pump
Custom rails
75 lb/hr injectors
Well tonight was the big night, we finally fired it up. The good news is Nolan was able to tune the idle in nicely. He will be the guy that can answer all the chipping sorts of questions. I'm still in the very early stages of learning that process. :oops:
I will take and post pics as we work through the process, if there is anything that anyone wants to see in specific just ask. :wink:
Tony
leroy
Sounds good Tony. I thought I was going to be the first to run with coated exhaust manifolds, but you beat me to it. Mine will be very similar, except for a TE-63 and starting with 55# injectors with a lower stall.
Jim
Tydriver
TurboLS6 Powa'
Congrats, Glad to hear it !! First was Brian D getting his running, next you !
Hopefully in the next week it will be my turn.. All of us just in time for the Nats.. I hope to see it at the nats.. This year is gonna kick arse from what I have read.. Hopefully alot of new mods like your GM ECM thats running 75#'ers.. NICE !!
Definitely getting excited that I will be seeing some FAAAAAAAAAAAAAAAST trucks this year...
10secTy
Sy-Ty builder and Tuner
Yep had to take alot of injector PW out but its idling nicely at 850 rpm and blm is around 128-131. BPW is at about .49 :eek: at idle which seams to be fine for the peak and hold injectors.
I lowered the F28 table from .091 to .045 i had it at .057 but was running out of lower limits in the VE tables to bring the PW down more.Idle was the biggest issue I think with using the 75's. Now that I know it is not a issue on with tunning!!! Tonight we try to drive the damn thing. Ohhh and Tony finnish building that damn wideband. :D
Man I can see alot of late nights from now till Nats.
Nolan
ParTyBoy
Re: Stretching the stock ECM
Comp cam 09-412-8
PT 72 turbo 8)
PTE exhaust housing
Built tranny
Sumped fuel tank
Custom rails
75 lb/hr injectors
Tony
magic to my ears :D 8)
leroy
Nolan
You using quasi-asynchronous fueling?
Jim
10secTy
Yep its quasi, I am baseing the program off of one of Brians 50's bins (thanks dude). and I believe Brian uses quasi all the time on his 50's bins.
Thanks
Nolan
10secTy
Well did some more chipping tonight. Found out that if Datamaster reads in the 30KPA that it is looking in the 40 on the Bin. This is on the open throttle VE table.
We got the truck to do between 115 and 130 BLM's revving out of gear. So then we hit the road. I found out that the 75's are very rich at low PW and then get very lean as the PW come up. This is no biggy just have to tune for it. So we did about 10 more chips and the truck is pretty driveable.
A little more tweaking tomarrow and I figure we will be ready to start tunning in the boost. Tony is getting the WideBand sensor tommorow and hopefully will have it working this weekend. I plan to get the drivabilty so so for now and focus on the WOT stuff as that is what matters for the Nats. TurboTony did not leave me alot of time to have the tune tight by that time :D
But from what I have seen so far the 75's will work sweet and give the rest of you Sy/Ty'rs a option to laying down the cash for a FAST set up.
We will keep you posted on our progress. Oh and for those that are wondering our goal for the truck is 10.9's for 20 000 can or about 14 000 US including the truck. We might be dreaming but hey if we don't try we will never know.
Nolan
ALBERTAN
Nolan
No that's not a typo, and no it not a dream based on what the old combo did. :wink: Phone in sick today and tune that bad boy! :p
jwaller
Evil Genius/SyTy Guru
hey tony or nolan. I would like to know how you did it. BC I am begining to have problems with my 50's being too small. and I wanted to use 75's. you are tuning a truck very similar to mine. I have the 412 cam headers and 61 turbo. jethot 2k coated & big valve vortec's. if you could send me the bin or an email that would be awesome. I am also already using a WB O2 and am interested in how you modded the ECM to make this work.
TurboTony
Hey John
In order to run the 75 lb injectors I changed out the injector drivers. This was Jim's idea and he should be the one to get credit for the directions to do so.
The part number is a Fairchild Semiconductor HUFA76429P3. I got some free samples from Fairchild by applying through their web site. I wish I had asked for more. You may have to embellish your request a bit to get them.
There is a plastic piece that bolts against the drivers. Remove it carefully. You may have to use a knife. Scrape away the coating from the solder connections. Desolder the drivers. There are little beads on the driver "legs". Make sure to get the beads back on the new driver "legs" in the same position. Put the new drivers in. Use the plastic piece to hold them in place, then solder, trim off excess. Put everything back together. Carry some extra fuses for ECM-1 until you are sure everything is working okay.
Jim
Here is the whole thread.... http://syty.net/phpBB2/viewtopic.php?t=11125&postdays=0&postorder=asc&start=0
Last night we had the same problem with blowing the ecm 1 fuse. The first time that the truck got into boost and the injectors started to really work it went. Swicthed to a 15 amp as per Jim and all seems well. :lol:
I haven't done any w/b datalogging yet, haven't actually finished the diy w/b board yet :oops: .
On that note, does anyone know exactly what year make or model of vehicle that I can find a w/b sensor connector in?
Tony
10secTy
Hey dude working on the Bin right now. Yes you can have the bin but let me dial it in alittle more then I will send it. I am working on it tonight, tomarrow and Monday I will sent it to you tuesday. The Driveability should be 100% its about 95% right now. We will also have a rough tune for boost. Since you have a WB already you should be able to finnish dialing that in. Or if you want wait a couple more days I will finnish dialing it in. Its up to you. :wink:
Nolan
jwaller
I'll wait til monday. I'm not running 72's now. but I'm definatly thinking about the mods and how to do it. I believe it's something I'll work on after Nats. I was just wanting to look at your coding for it now. you know give me something to think about.....
10secTy
Ok I will send it out. The truck will be at the Nats if you have more questions.
Nolan
Falco
Tony,
You could find the connectors on Honda Civics/Accords from the early-mid 90's. Look for it around the headlight harness, near the brake master cylinder/booster, on the passenger side fender near the firewall. On some models the distributor connector was the same too.
One remark. This project of yours is really amazing. Could be the #1 alternative for the guys fighting for a 10 sec timeslip. So good luck, and keep us informed!!!
Peace,
leroy
Tony,
I didn't bother with the Honda connector. I just removed the cal resistor from the O2 sensor connector and mounted it on the board. Of course, the resistor will have to be replaced when the O2 sensor is replaced, but that's not a big deal. You can also just run 5 wires to the sensor instead of 7 this way.
Jim
TurboTony
Hey Jim,
I kinda like your idea about losing the honda connector. How exactly did ya do it? I was thinking that a guy could leave the resistor in the connector and just put a short set of wires to it near the w/b controller. It would make life easier if the sensor ever needs replacement.
The other option is to get a connetor from FAST. They use the same on with their setup. Just a matter if they will sell the jumper harness for a reasonable price. :roll:
Falco,
That has kinda been the idea all along. I have 110% faith in Nolans ability to tune it to that point, just hope that all the hardware is good to go as well. :wink:
Tony
leroy
TurboTony said:
Hey Jim,
Tony
Just use some needle nose pliers to pull the sensor connector apart. The pliers can then be used to remove the resistor. I soldered the resistor onto the board with a very short set of jumper wires. I ended up using a weatherpack fitting in place of the stock connector to make it easier to take apart and put back together. Hope that makes sense.
I've got the code change to read the wideband output on Datamaster or Diacom if you need it.
Jim
10secTy
Brian has done the code change we need for the WB (Thanks agian dude!).
Sounds like TurboTony has been working feverishly on the WB so we should be able to start the REAL tunning!! 8)
Now we only have Datamaster times on the truck and I know its not the track but it will due till next Friday. At 14.6 psi truck ran a 12.38@110 with 1.87 60' and zero knock. We will see how rich it is tomarrow as I have it set up very safe(I think - thank god for WB's) right now.
Till tomarrow
Nolan
