Just got my Typhoon on Thursday, came from Chicago with 121k on it. Motor seems strong and doesn't leak a drop, however the streering is mad loose and it has the famous vibration at high speed. I've decided replacing the idler arm is a good place to start.
I can't seem to get the old arm off, it is stuck at the ball joint. I've tried tappnig the loop and whacking the **** out of it with a pickle fork and hammer to seperate it and no go. It doesn't want to budge at all. This is driving me crazy, it should be a simple swap. I'm about to do something drastic and try cutting off the thread on the bolt that hangs down and then drilling out the middle of the bolt from the idler going through the loop in the steeriing linkage. I figure if I drill out a decent enough hole it should have some room to compress when I hammer the pickle back in there. The down side is if this fails I can't put the nut back on and keep driving it with the bad arm.
Someone please stop me from doing this by providing some advice or another approach.
