I have a brand new holset hx35 with .76 ar housing. I also have a tial 38mm wastegate. I had a 14.5 psi spring in for a while and it was right about there on the gauge. I had zero knock. never saw it come off 0 once. I decided to put a 16 psi spring in and noticed its only boosting to just shy of 15. so just to test I put a 17 psi spring in. and its 15 psi on the button. but now im seeing 5 or so degrees of kr. how could only .5 psi cause that and why wont it go above 15 psi. I checked for boost leaks and it all seems good.
I do have the wastegate ref about 10 inches before the tb. afr is 10.6-10.8
