MR_MNZTR_SY
today we looked into my boost problems (cant build much abouve 5 psi) and what we found out was that the soleniod is functioning properly, there is nothing mechanically wrong with the wastegate either. if we ground out the solenoid, i make boost like normal. we also hooked up a vacuum gauge and it matched up with the vacuum gauge on the truck BUT the ecm is reading vacuum (and boost) way above what is actually happening. the map sensor voltage is a little off, but it is a new sensor so i dont BELIEVE that that is the problem. what we are kind of thinking is that maybe the chip is bad (atr pitbull chip i believe, its been in there since i bought it) i do have the stock chip and am going to try to swap them on monday and see what happens. either that, or the ecm is bad. lovely. any thoughts? suggestions? anything i may have overlooked?
