stutter and light
turbotyphoon69
first, i keep gettin an IAC valve code, and i already put in a new one. :-? The other part is when i punch it or get on it half way it hesitates-sputters and drops RPM. Then it picks back up. :x
MyTyphoon1993
Re: stutter and light
Is it a code 35, if so, could be an egr leak.
Drac0nic
it's easy enough to check if it's going nuts, just pull the vac line off of it and see if it still sputters, mine had a diaphram in it that was bad, so I just left it disconnected for 2 or 3 months in my Astro, finally got around to filling it full of epoxy this weekend. I strongly reccomend either cutting the vacuum part off and epoxying it or getting/making a block off plate for it, they're a #%#* of a lot easier to re-install then the EGR valve is, those are a dog to remove.
QUICK STORM
B.A.M.F. BMW Tech
check anything that has to do with fuel pressure i.e. fuel pump, fuel filter injectors lines. don't recommend disconnecting egr for a variety of reasons.
