suggestions for l35 upgrades
silverblaz
just like the title says what are your suggestions for upgrading the L35s
rocker arm suggestions probably sticking with 1.5s as of right now 1.6s depends on the cam i was wondering proper partnumbers that would work with the heads
ALSO does anyone know if the new vortec shaft mount rollers will bolt on the L35s or no?
valves oversized or not?
bottom end is going to be 4bolt with eagles je pistons cryo'd crank trying to figure out what to do with the top now
cloneman315
Re: suggestions for l35 upgrades
the vortec upgrade is not all that mutch more,and well worth the money!!
MRKING
New Parts for Old Trucks
I wouldnt waste your time with those heads . Keep them stock until you can afford some vortecs or brodies .
silverblaz
OK took your advice i went out and got a set of vortecs with the shaft mount rollers on them
