Supercharged and 6 Speed Syclone.
jwaller
Evil Genius/SyTy Guru
Re: Supercharged and 6 Speed Syclone.
VermontTy said:
Basic question for those running both a turbo and SC, the top end rush from the turbo doesn't "overfeed" what the SC can pass through?
In the view of the general public, all of our trucks look like ass. :rant:
I was wondering this myself but I am guessing it has maybe something to do with the bypass valve thats on the SC. I dont know but the think runs like stink on the topend.
myclone
jwaller said:
ya it's really weird but I think he just ripped the stock cooler out of the radiator and stuck it there. I'm not sure but I guess the one that is in his rad either doesnt work or didnt get around to hooking it up.
Yes, its the factory oil cooler without the radiator around it (I took a busted rad apart to see what it looked like inside eons ago).
BigAl...
John are you sure they have a 3.73 gear in that thing? whats the ratio of that 6speed o/d isn't it .6something and the stock overdrive is .7something which means the whole six speed advantage would be negated with the 3.73 final ratio. I forget now what the rpm at 60mph (it's been that long since I drove the syclone) on a stock tranny but I don't think it's 1100rpm maybe they actally have a 2.73 final in the front and rear diff. anybody elso notice the discrepency?
BigAl...
Mathematically it doesn't quite add up, it would be around ~1450rpm with stock tires. However, the previous owner may have not changed the DRAC properly (3.45:1 would register 1350rpm). The Tach might and Speed might be off some
BigAl...
Dave, you beat me to the punch, I was figuring it out when I got the notification of your post, there's deffinetaly something wrong there, eitherway alot of work went into the truck, even if I don't like it I can appreciate all the hard work.
BigAl...
jwaller
yes both of you are correct. I didnt quite believe his 1150 # as that barely above idle. he said it wont get out of it's own way at 60 and 6th was almost unusable. 1450 sounds like a better # and more correct to me.. also I know he does in fact have 3.73's but did not change the drac and he does know about this error. as for his claims on fuel economy he has taken this all into acct and claims the numbers as right.
THEMADTYPH00N
I dont believe that RPM#. My buddies 6 speed Camaro has an even taller 3.42 rear end gear and it doesn't even cruise that low. Cool truck none the less. Nice to see people thinking outside the box.
MRKING
New Parts for Old Trucks
seems like alot of work for good gas mileage . what are the future plans for this truck ?
Tydriver
TurboLS6 Powa'
While some idiots here would argue thats no longer a Syclone, I personally think the concept is cool, in fact before I went with Gen3 power I contemplated something similar to that, except with a little better follow through in the 'fabrication' department (and no 6 speed).. I was going to run a stock TC and use the magnetic clutch off the mercedes benz cars and run them parallel instead of in series.. But the idea and the concept is still hella COOL..
What was reason for TOP END car ? He running it in silver state or something ??
Crimson93Ty
PITA new guy
I've seen the SC+turbo charger concept used on diesel engines before but never on a gas vehicle. The supercharger made up for the turbo lag so the truck could pull away from the stop light and then, when the turbo caught up, the higher pressure would push a valve shut and the SC would go into bypass mode as JWaller pointed out. Of course the turbos on those were big as trash can lids.
jwaller
without going into things that need not be put into the public, I dont think there are any, just drive it. believe me I tried to convince the guy to clean things up, maybe go with a more reasonable single turbo, but he's set on leaving it as is and one day building a good bottom end for the thing.
blackbeast1
on my truck before i changed rear ends, i cruised right below about 1100 rpm, with some really short stock gears. 308's maybe, i dunno. no RPO in the glovebox. Trust me, it really was just idling down the freeway, and i had to downshift a lot to 5th for hills and such. Anyways now with 342' it's cruises at about 1250-1300 rpm, and really is better to drive on freeways, not to mention more fun at stoplights.
You also have to remember it's possible he has a 93 T-56 which have a final drive of .62 instead of .5, but that should make his rpms' even higher--just thought i'd throw it out there
Jer
Don't taze me bro!
jwaller said:
well the former owner made his own adaptor plate to bolt the SC to the stock lower. from what I understand it was built as a top end machine, not really for draggin. it is very fun as you have the instant responce of the sc and then the top end rush of the turbo.
the guy also made his own adaptor plate fashioned from the chip foose quadraduce project to the the T56 to mate up with the BW 4472 case. it is an amazing piece of engineering although the truck looks like it spent time in a war zone.
with the tuning and 6 speed it will cruise the hwy @ 60mph and 1150rpm's it also has 3.73 gears. and 25mpg.
Why would someone take something as aerodynamically challenged as an early 90's S10 to make into a top end machine?
Tydriver
TurboLS6 Powa'
Why would anyone take an S-10 body, make it AWD, throw a turbo on it and hand some funky ground effects on it ??
WHY NOT ?
If we all wanted to drive Poopras or Vettes it would be a pretty boring world..
Jer
Don't taze me bro!
WHY NOT ?
It's kind of like building an object to tow very heavy trailers and using a Geo Metro as your platform.
Seems if top end was your goal, you could pick a better platform to start with.
442typhoondude
Ty'less Bum
I'm no expert, but I would think running all of the factory junk would make this a recipe for disaster. The factory bottom end is already heavy, slow and weak enough, why add a supercharger on top of the turbo? It's a cool idea and all, but I wouldn't expect this thing to last to long with the extra boost and the stress on the rotating assembly.
jwaller
your are exactly right. thats why I said the current owner(not the builder) is planning on building a good bottom end.
