Surging and a coupler other Q's
s_blazin
Ok this is a long one so bear with me.
My truck has a surging issue. It seemed to run fine with charge pipes off and a filter on the throttle body but it seemed like when i put the charge pipes on yesterday it started doing it. i was trying to set timing but couldn't with it surging. now with some throttle above say 1500 it will stay steady no surge....but i was thinking setting timing above idle, it wouldn't be correct, am i wrong?
New or good items i've checked off
throttle body and intake gaskets
Under the tb the vacuum port is plugged
new wires
plugs
distributor
3 bar
10 n 1 chip
all new vacuum lines
all vacuum hoses and ports are plugged, can't find any leaks
Truck is also A/A
have datamaster hooked up and running, but i'm new to messing with this stuff and don't really know what to look for
don't know if it makes a diff but boost is set at 12psi so nothing bad happens til it can get tuned
http://www.sytychips.com/10n1description.html
mine is this style but with the red button on the front and a key opening, as far as i can remember nothing on it saying it's it's an sgt or somebody elses.
Now question number 2 is i have no idea what that chip was set up for i was told 55lb injectors but it has 44.5's in it and this was supposedly the setup it was tuned on.
and i have a guy that is trying to decode all the encryptions to see what the chip is set up for but is having some difficulty since apparently the encryption is heavy.
As i said timing is not set, i thinks it's 8 deg advanced right now but the timing light is a pos and kept cutting out when i'd start turning the dial past zero,
but i have no idea what to set the fuel pressure at, i brought it up from encrements of 2 from 42 to 50lbs and it's not happy, idle sucks and at 50 it wants to die, and throttle response sucks.
where do i start, besides buying a new timing light tomorrow and hitting up the guy with decoding my chip?
Sportmachines
Re: Surging and a coupler other Q's
If it were me, I would pull that chip out, til you can get some more info on it. Drop a stock chip in it, and set your baselines, ie timing and fuel pressure. If its running ok in that fashion, you can start to add the other components and either isolate the problem, or figure out whats going on.
HTH
s_blazin
HTH
I will keep that in mind, although i don't have a 2 bar or a stock chip and the stock injectors will need to be cleaned since it has been 8+ yrs since they've had fresh afuel in them.
Whats the wbo2 say?
Unfortunately it's not hooked up yet, it's on my list of things to do this coming weekend.
Thanks for the comments guys, keep em coming if you think of anything else
s_blazin
well i guess i know what i need to do next then. i will try to get it in sometime this week. it's so close now i'm gettin antsy
s_blazin
well i got the wideband nearly all wired last night, one thing i am wondering, it has an led light and button for calibration. but i'm wondering how accessible do i need that? am i going to need to calibrate it often? my guess is no but thought i'd ask since i have no idea.
was thinking for ease of installation i would just wire it in under the dash, instead of having to extend the wires for it to be accessible on the dash.
put a smoke machine on it but the hinge deal the throttle body plates are connected to next to the tps was leaking enough that i couldn't build pressure to find any other leaks. guess i'll have to pull the TB, cap the intake and try again.
my guy is working on the chip still, can't get anywhere until i know where i'm going.
might be easier to put a stock chip in it and go from there? anyone have one? stupid computer won't let me access the parts for sale area. keep getting a fatal error screen.
the darn thing does not want to idle as soon as i unplug the timing connector. messed with fuel pressure and it doesn't care. i'm stuck
jklein68
At the risk of sounding stupid because it looks like you checked all this...but depending on what you mean by "Surging" it seems like a really bad vacuum problem.
s_blazin
well thats what it seems like to me as well. it has to be. i better re smoke it with the TB off.
it has an erratic idle, up and down. it was only doing it with the timing connector unplugged at first, and only after i installed the charge pipes. i can't imagine that has anything to do with it, must be coincidence.
but now all the sudden it just won't run with the connector unplugged. it's very unhappy. i can't even time the bastard with it doing that. there must be something i'm missing, something small and stupid i'm overlooking.
whiteTy1214
i am fighting a engine surge also, but only while driving at a coast down, idles good. did tune up and all the vacuum lines also. even installed a new throttle position sensor but no help. i want to do a smoke test also. i got throttle body gasket kit. and thinking to clean the iac valve as well. been really fighting me to find it. i feel your pain. i got a new dampener (stock) to install, since i found it walking off the ring.
then i will reset timing and go from there. i also really need to get a wideband gauge as well to see my readings. if anybody has comments. i would love to hear them also. thanks and good luck at finding this problem
When I hear an engine surging, my first instinct is the IAC passages or IAC Valve is bad. If the throttle body stop is adjusted too low it will also surge. You can look at the datamaster counts to see if the IAC counts is really high. I normally you would see count in the 20-30 range when warmed up.
jeepruby04
I believe your right, the 10 n 1 is a 2 bar, I have one, you might also check that your harmonic balancer ring hasn't slipped, mine did after I put the new motor in, it was 30 degrees off
whiteTy1214
checked my iac valve. looks cocked or pintle valve bent. passages look ok. even the valve itself is some what clean. but not sealing good. 3/16 on one side, maybe a 1/16th on other side, can tell becuase it is clean where it makes contact. got a new one coming today. hopefully this is the end on the engine surge problem. thank you for the info. and advice
s_blazin
The IAC was the first thing i pulled off and checked, there really wasn't much to clean it looked pretty decent to me and the passages didn't look clogged either. i will reinvestigate that though, just to make sure.
I thought the 10 n 1 chip was a 2 BAR stock injector chip?
You fellas just may be right, but if so then i am confused. because this truck i'm certain had this chip in it when the guy built it, it wouldn't make sense to me for him to have had it all in a ty running and tuned, and then when swapping it all over to a sy and putting the wrong chip in it.
which leads me to my next question.....are there any other chips that were ever offered besides the 10 n 1 found in the link below that had a button to change tunes? i ask because mine doesn't look the same as that one so maybe i have something else?
this is mine
