Re: SwainTech White Lightning TBC-EX coating
Here is a copy of the email Richard sent me. Explains alot.
Tom,
Thanks for writing. Here is the bottom line with exhaust coatings. Airborne, Jet Hot, HPC and all the other companies applying "ceramic" coatings on exhaust parts are actually applying a high temp paint. Because it is a paint, it can have a pigment or dye added to it to make it different colors like black or blue. It is also the reason they use temperature ratings because the paint will literally burn off at relatively low temperatures (about 1,200 degrees F).
What we apply is a real ceramic thermal barrier coating. It goes on in multiple layers. The base layers are bonding materials, the mid layers are bonding material and very pure ceramic and the top layers are ceramic. Because it really is ceramic, it does not burn off at temperatures that you would see in an exhaust system. Here are the things that can occur with our coating on a turbo system:
1) If you do get the parts hot enough that they are about to glow red hot, some of the bonding materials can bleed through the coating and give the coating a spiky appearance. This will not damage or impact the effectiveness of the coating. You can just brush these spikes off and keep on running.
2) If you do get the parts hot enough where they are close to glowing red hot, there is a chance the base metal will expand more than what any ceramic can expand. This can fracture the outermost layer of the coating which is the most pure ceramic. This does not happen often and if it did happen, you would still have about .010" of good material left. You would still have the best insulating and most durable coating available protecting your parts.
Because the coating you have on there is essentially a high temp paint, we can strip that off with a blasting procedure. It usually cost about $20-30 to strip off an old coating. Most v-6 turbo manifolds cost about $175-200 to coat, turbo housings about $75-100 and additional tubing cost about $40 for each foot in length for each tube. Exact prices will be based your specific parts, but this will give you a good idea of what to expect.
About the only way to get our coating off would be to grind it off. It is that durable and effective. Typical turn time is about 2 weeks in our shop.
Richard
Swain Tech Coatings
