Swap oil pan?
Injected1
What is the easiest way to swap oil pans? I was going to pull motor mount bolts and jack up the motor on the harmonic balancer to give me enough room to slide the pan out? Also what is the easiest way to make the new pan a 10an fitting for the turbo drain (stock pan) weld a new bung on or just convert the elbow to 10an? What is the thread pitch and size of the stock elbow?
