Re: Switching to External Wastegate
"Now to deal with the old wastegate. You have several options. 1: shorten the rod as much as possible 2: shorten and wire the arm shut. 3: weld the puck shut
Your aim is now to prevent the stock wastegate from being pushed open by exhaust pressures, wrapping wire will keep it from opening, but looks pretty awful. Just adjusting the rod may allow for some movement still. And of course, welding is quite a bit more permanent then either.
We simply wrapped some wire on ours."
