Smkur50
SYTY Fleet owner
Gauging interest on it.
Basically 77k original miles
BAD-
-Factory paint 6.5/10 original paint is peeling from hood and starting to peel on top of cab, minor dings, rear corners cracked, rest of cladding is all there, just installed new OEM right rear arch.
-ZR-1 style wheels have some of chrome flaking
-front of oil pan leaks, has a stock syty oil pan but modded to fit on 03 vortec engine.
- passenger side carpet has rubbing about 8 inches around..I do have 69k mile original sy carpet I can give with the truck that is in great shape.
-headliner needs redone
-will die at idle when in park or neutral, needs some parameters addressed in tuning I believe. Also cold parameters are off..once it warms up runs great other than P/N idle
The good far outweighs the bad on this truck though
Good
Engine-
2003 balance shaft vortec, stock shortblock with 212/218 cam and timing chain tensioner
AC Delete
58mm BBK TB,
Vortec heads with LS valvetrain..ported by turbo time
ported lower intake modded for vortec heads
ported upper intake
edelbrock aluminum waterpump
new Blue Max wires just installed
MSD distributor
ATR headers
67 dual BB presicion turbo with internal wastegate downpipe
3 inch catted exhaust, thinking ATR
Big K&N cone filter
wideband and emulator all mounted in glovebox
March underdrive crank pulley
powermaster alternator
Fuel System- E85
-Weldon high volume external fuel pump
All braided fuel lines, billet fuel rails, 60lb hi imp inj, external regulator all E85 compatable.
Sumped factory fuel tank
-air 2 air cooler mounted in factory lower intercooler location
-electric fan
Trans/drivetrain
-2800 stall/Waller Trans
-huge trans cooler
Suspension-
Dual style QA1 coilover in front with tubular A-Arms
-poly sway bar bushings
-brand new MOOG idler arm just installed
Wheels-
Chrome ZR1 style 17x9 front 17x11 rear
Front 275 nitto NT55's with 80% tread
Rear 315 nitto NT55's with 20% tread
Brakes-
Front Corvette calipers/ drilled rotors with stainless caliper hoses
Rear stock drums
ABS Delete
Interior- 8 out of 10
White face guages, no rips or burns in seats, lumbar bulbs are there but not attached looks like the hose got cut to them.
-Old school pioneer 1.5 DIN CD player
Im sure Im missing more just cant think of it all. I have datalogged it, wideband works, no knock issues seen, just needs cold tables adjusted and P/N idle fixed. I have not tried to program it yet. Remember the tuning is set for E85 right now not regular gas but could be switched.
Why am I selling? Well Sy 1356 is just sitting and not making any progress because this truck runs and is a blast to drive. I have considered just keeping this one and giving it a fresh paint job and being happy for a while but I want a LSx Syclone, and Sy 1356 has more going for that.
So I do have a vid of a street launch so you know it runs and runs well(2psi launch 16psi max boost)
http://www.youtube.com/watch?v=V1bupXgHnPI
Been trying to get a clean 1/8th mile pass at our local track but for some reason or another rain/timing lights at track dont work/schedule seems to get in the way. I can say for sure it does a 8.31 at 86mph and 1.87 60 foot time but had a battery terminal come loose and lost power for a split second right after the launch(damn violent launches..lol) I was going to try and pull a 7.9x or better time before I sold, I do think it has it in it or better.
So, I wouldnt expect the stock shortblock to last forever if you push it, you might be able to run low boost for long time and be OK, but for a bit more I can throw in a already built 03 shortblock with forged pistons/eagle rods/cam 218/218 along with the truck for another $1k
Will get more pics soon.
BAD-
Good
Engine-
AC Delete
58mm BBK TB,
ported upper intake
MSD distributor
ATR headers
Big K&N cone filter
Fuel System- E85
-electric fan
Trans/drivetrain
-huge trans cooler
Suspension-
Wheels-
Brakes-
Rear stock drums
ABS Delete
