Sy #40 eBay (sold)
SVO
GMC Racing
71,500 miles.
eBay ad; This is a 2 owner vehicle. The first owner was a retired veteran and had it for 30 plus years and had it serviced at the same GM dealership since new. I’ve put less than 1000 miles since purchased and 300 miles with all the modifications. I have invested over $19k in upgrades and maintenance. This includes new 2OG turbo, SM Race intercooler, larger intercooler pump, intercooler fan, Brembo 4 piston calipers F&R, brake install kit, 3" downpipes, 3” test pipe, ZQ8 steering box, 255L/Hr Racetronix fuel pump & hardwire kit, adjustable billet fuel pressure regulator, silicone vacuum kit, aluminum intercooler scoop all purchased from Sportmachines. Bosch 60lb injectors, Scanmaster 3, 3 Bar MAP sensor and turbotweak chip were purchased from TurboTweak. Also includes PLX Wide band O2, All new suspension bushings including upper and lower control arms with new bushings, upper and lower ball joints and F+R rear Belltech shocks, Belltech lowering kit, Belltech rear sway bar and Hooker Black heart steering shaft.. LED headlights. New A/C Delco battery, A/C Delco IAC, NGK spark plugs, A/C Delco spark plug wires, A/C Delco cap and rotor, A/C Delco EGR, door weather stripping, window seals, Bosch window wipers as well as recent oil change and alignment. New 18”x 8.5” gloss black wheels with New Firestone Firehawk Indy 500 tires. The interior is all sorted and includes a Momo steering wheel, Delco stereo and new floor mats. The instrumentation lights have been changed to LED. Everything works including the A/C. I have receipts for everything. The original books and window sticker as well. The paint is not original as the previous owner had it painted. No rust. I have all the original equipment including turbo, intercooler, steering wheel, brakes, wheels and tires.
(Sold) 10/01/22, 30,650.
