kind of a long one but bear with me please
I know there were many changes to s series in 91 but did sy/ty get bigger rear brakes or did the whole s series line get bigger in 91?
explanation below
So changing the rear brakes on my 89 blazer i found that the wheel cylinders are only held in by a spring clip.
when i bought my new napa cylinders there was instructions folded up for a rear brake reinforcement kit that provides a bracket the either replaces or coincides with the spring clip since apparently it was a bad design and they seem to auger out the backing plates after years. well it is like 2 weeks if ordered and plus shipping.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=UBP25851_0063338695
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=UBP25851_0220766941
spring clip is a pita and i'm beyond pissed.
i have the backing plates off a 92 ty and noticed that the wheel cylinders bolt in instead of spring clip....sweet!
but the backing plates are much larger. which tells me that the drums and shoes are larger.
however on napas website 91 sonoma shows the same wheel cyls that i have, spring clip.
i decided to look for pro 89 backing plates at the wrecking yard but thought someone here may be able to answer this before i'm able to go out to the yard, on sunday.
so did sy/ty get larger rear brakes or did all s series get larger ones with the bolt in wheel cyls in later 89 yrs??
i'm searching around as we speak for this as well
edit
hmm 92-93-94 jimmy has this style wheel cyls
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=UBP37967_0074897787
91 jimmy
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=UBP37625_0312667988
atleast per napas website, but i have had them be wrong before
91 syclone
92 typhoon uses a totally different one all together
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=UBP37854_0307748555
93 typhoon
hmmm looks like 92 - 02 uses the same cyls
and 91- to 79? dunno what that means, maybe full size 1/2 ton truck
UBP37625 91
UBP37967 94-93-92
so from what i gather 92-93 ty got bigger rear brakes with diff cyls than all other s series, interesting
explanation below
edit
91 jimmy
91 syclone
93 typhoon
UBP37625 91
UBP37967 94-93-92
