Syclone/ECM/California Model?
Will try to make this as short as possibe, but it's gonna be hard. I have been having idle,surging,bucking and stalling issues here and there for about two years now. About a year or so ago, Big Mike came to help me work on the truck and he brought his spare ecm and we tried it and my truck ran great with it. We did not drive it with it in, but it idled perfect with it so we decided that was the problem.
Couple of days later I took my factory ecm to advance auto and got a remanufactured one. I am not sure that they used the numbers on the ecm to bring it up on there computer or just put in syclone,1991. Anyway I purchased the ecm and put it in my truck.
The truck ran better but still was not the way it should be.
Gradually over time, it has been getting worse. Idle going up and down, stalling when you put it in gear, bucking, surging , going into limp mode and you name it.Its done it.
I have went over every inch of wiring,and vaccum lines under the hood and it is all good. New iac,dist module,tps, tune up and so fourth and nothing made any difference. I have no data master or any test equipment and the last time I drove it, It died on me six times and now is not driveable.
I made an appointment at the most reputable auto service center in town. These guys specialize in gm products and most of the techs used to work at the dealership at one time or another.
I only had one code stored in my ecm. I dont know the number but they said it was from tring to start for an extended time. I even gave them my gm factory service manual for reference in case they needed it.
I talked to the boss yesterday and he told me that they tested each wire from the ecm to the dist and all the connections on the dist and it all tested good. He told me that the problem is the ecm. By the way. I took the ultimated chip out and installed the factory chip back in with the two bar map and it still ran the same before I took it to them.
He also told me that he called GM and was on the phone with them for 40 minuites and GM looked up my ecm with my vin number and I am supposed to have a california emissions ecm. Is this possible? I cannot remember what my ecm number was or the number of the remanufactured one was or even the number of the one he just orderd.
The new ecm will be here on monday and and we will see what happens. I don't care at this point what kind of ecm they put in it as long as it runs right.
Another question, My decal under the hood under the hood in front of the radiator says california emissions on it. Do all syclones have this decal?
Just leaving now to go on fishing trip today, but will check back in this afternoon when I get back to see some of the comments from you guys......Fred
Baythan
SY2TY2SY2TY
Re: Syclone/ECM/California Model?
Just went out and checked. The last line on the decal reads "EPA Regulations applicable in California".
That's the only reference to CA on the decals, and I'm assuming all of the trucks have this.
For Syclone and Typhoons, their is no different ECM or chips for CA.
MikeRenz
not stock
i just checked the comp nine rpo's for your truck and it does NOT have the YF5 california emissions certification code.
vmack
Reman ecms have given me problems in more than one car.I think when they check them or bench check them it just doesn't work out real well, what ever the reason.
What is the correct part number for the gmc ecm. I want to get the best one availble.
