syclone fluid levels
#2875
built, not bought
i don't have a manual, could anyone tell me about how much coolant the IC system holds and how much engine oil is recommended in the manual? thanks.
Loeryder
http://www.sytyauthority.net/
Check under the maintenance section.
Most of the capacities are there.
Do a couple searches all of this stuff has been covered a ton of times.
You'd be suprised how much stuff is archived here already.
good luck getting your fuilds all changed, by the time you are done changing them all its time to go back and start over...
