Synapse Synchronic External Wastegate
BLACK92TY
It's never enough
Anyone running this?
http://m.youtube.com/watch?v=yN51ZrwLlMc
Installed tonight. Got boost. However it doesn't feel as though the wastegate is "cracking open". No WOT passes yet. Very, very touchy throttle response. Spiked once on about 60% acceleration. Was nervous I'd pop the upper IC pipe so it's parked until tomorrow when we have more time to mess with it.
I did forget to install the valve seat that came with it. Wondering if that has anything to do with it.
atkonkler
Is this your bush?
Re: Synapse Synchronic External Wastegate
That is really interesting ! Good catch man ,if you end up running it let us know how it goes!
BLACK92TY
It's never enough
Dig was the one who recommended. It is a neat little set up.
I'm wondering if I've got the set up configured properly though. There is not a port at the top of the wastegate like most externals have (I would assume most have anyhow) to run a vac line from a regulator as the archives diagram shows. So basically I'm running vac just straight off the factory turbo boost port straight to a "Y" to my two different port settings.
I am not running a boost controller and I don't have a regulator. So I'm either WAY off or....WAY off? lol
I unhooked the pigtail that runs to the factory boost solenoid. And temporarily wired the factory arm shut. The truck makes boost but it doesn't feel safe. That and I don't hear the external opening whatsoever. It it is it's barely opening. The response is touchy but it's spiked on me twice and I've even heard a very slight "lean pop" which I don't like hearing.
Wishing someone else has this set up so I could learn from their mistakes.
BLACK92TY
It's never enough
Isn't the stock boost solenoid basically non-functional now? I unplugged it and just ran a vac line directly off the factory boost port (nipple that faces towards radiator). It's creating lots of boost which I'm severely confused on. The archives show that once the factory boost solenoid is unplugged you should only be able to create like 8psi max unless you're running a 2bar or 3 bar. Is that correct?
What does "from n/c to n/o" mean?
Darin
You mentioned you wired your stock wastegate shut. No matter what, the factory wastegate is non functional now, in a closed state. This means that unless you have a method of bleeding off the excess exhaust before the turbo, you have NO boost control. With the solenoid unplugged and the factory wastegate NOT wired shut, you'll see 8ish psi, regardless of 3 bar or 2 bar. It's mechanical, it don't care if the solenoid is unplugged :)
Methinks something is up with the external. Or, I would start with it hooked up in it's simplest method, at it's lowest boost setting, and see how that works. If it still spikes, or goes over whatever it's supposed to be set at, then suspect the gate itself.
On another note: I would suggest attaching a smaller pipe to the outlet of the wastegate to direct the incredibly hot gases away from anything that might not like it. It'll also help to keep crud and road debris out of the wastegate itself.
BLACK92TY
It's never enough
So it's not a big deal that I'm not running a pressure regulator? Or are you saying I should figure out a way to run a bleeder before the gate?
Thanks
BLACK92TY
It's never enough
I was going to have my guy weld a dump but there just wasn't a ton of room. We're going to try and run something bendable if possible. That or get something to cover up the wires. I didn't like the fact that it was hovering over a few wires either.
tunerpike
Since you don't have the stock wastegate any more the 8 psi doesn't come into play. N/o and n/c refers to normally open and normally closed coming off the stock solenoid. I want to say the an external gate needs to be hooked up N/O.
BLACK92TY
It's never enough
So the solenoid is still operable? Even if it is unplugged? Or do I want it plugged in? Guess I'm confused now.
I'm just not sure on where I'm supposed to run vac lines from I guess that this point.
Darin
Isn't that the benefit of this waste gate, not having to run a pressure regulator or boost controller?
I have always use Tial products in the past for waste gate and blow off valves. Simple, boost controller, work well. I don't have any experience with this new fangled waste gate that you have:)
BLACK92TY
It's never enough
That's what I thought.
There's just no information on running vac lines specifically for this model. All the SyTy stuff says you need to run from the turbo to a T, one headed to a regulator to the gate and the other headed to the gate.
This one there is no port at the top where I would run a line from a regulator. So I'm just assuming I don't need it.
So I guess I just need to figure out where (on the turbo) to run a vac line to the gate itself. Unless I have it right. But if I had it right the gate would be opening... Hmmmmm. Is it 5 o'clock yet? :holdsguntoballs:
BLACK92TY
It's never enough
Just got off the phone with Synapse. Got it all figured out. I'll post later after I re-route a line.
BLACK92TY
It's never enough
Well after re-routing some vac lines I thought I had it figured out.
Turns out it's based off the factory boost solenoid. Guy said to take any vac lines off the solenoid and "let the truck idle" whichever port is blowing air is the one I'd run the line down to the gate. Well that wasn't easy to find as the turbo sits right next to the fan. But in actuality if that's the case there's really only one of three ways this line can run and it can't run to the vent. So that makes it one of two ways.
Think I got it on the right one. As it blew the vac line off after partial acceleration. Didn't zip tie one little part just cause I knew I was testing. The other way I had it there was nothing but lag and spike.
So I zip tied the last piece figuring I had the vac lines right. Took it out. Boost was obedient until about 65-70% throttle then another frickin lean pop. Geez. This time it was loud.
Could this be leaning out because the boost pressure is jumping and the computer is trying to starve it for fuel?
Also, everybody says these externals are loud. Would I have to try and listen for it if it was working or would I know it's opening?
Blah
BLACK92TY
It's never enough
Well we pulled the gate off and made some adjustments with the spring/preload spring combo we were running. Stopped and bought a new boost solenoid. Put it back together and....WSSSSHHHHHHHHHTTTTTTTT!!!!
Definitely meets my approval. Throttle response is night and day. Boost is consistent. Little bit of breakup up top but that feels more like an ignition issue. Haven't replaced the plug wires in quite some time so I'm assuming that's the culprit. Now I gotta find something else to mess with. Next stop 20g??? :D
