syty 4.3 or 5.3 vortex, what do you guys think.
scottyblazinlow
Red tyclone
I have a 93 s10 blazer and a complete syty 4.3 that needs redone. Do you guys think I should do, buy a 5.3 vortex and make it a LS1 or redo the 4.3 turbo. Right now the blazer has a CPI 4.3, auto and its 2wd.
SEL777
One of 101
Re: syty 4.3 or 5.3 vortex, what do you guys think.
What do you want to do, more importantly how is your bank account? If money isn't a issue.....swap the LS in. Not to say building a turbo 4.3 is exactly cheap. I'd start with a new front bumper cover. When you get started put up a thread in the projects section.
Beavis
Still plays with trucks
LS it and sell the sy stuff to pay for the swap. :2cents:
MRKING
New Parts for Old Trucks
I can't imagine a bum syty motor selling for enough to buy a Ls motor .
Realistically , your budget should clear the path to this answer . Have you sat down and figured out what types of goals you want for the truck in regards to speed desired ? Are you able to do a complete swap and re-wire yourself ? Potentially with standard setbacks , you could be down for a month .
Hopefully this isn't your daily driver ? At a minimum you will spend lots of money , create lots of headaches , and be without an s10 to drive for weeks .
scottyblazinlow
Red tyclone
Im looking around mid 12's
scottyblazinlow
Red tyclone
Why? You're better off with the 5.3 stuff. The LS1 heads have larger combustion chambers which will give lower compression and the intake doesn't flow well enough to bother with it. A nice set of heads, a cam, and a good tune would probably do you wonders.
What would be a good setup for my syty engine to get me in the 12's
the baPhoon
SEARCH.
Right next to links in the upper right hand corner.
Thank you come again.
