PA SYTY ABS unit
1BADV6
ABS unit from a Typhoon. Worked when removed from truck, has been in storage for years. $25 plus Paypal fees and shipping.
thanks
Ryan4421
Re: SYTY ABS unit
Seconds if Rice Eater isn't interested. Let me know shipping to 33434 and your Paypal info if it's still available please.
1BADV6
Re: SYTY ABS unit
The only way to tell is to hook them up and see what codes you get and if you can clear them. A 92 in a 93 truck will give you rear wheel speed sensor open codes. And they won't clear.
A 93 unit in a 92 will give rear speed sensor code, but you may have to drive it to set it. It should clear until you drive it again.
You can swap the front module that contains the electronics onto the rear section that contains the valves and solenoids. For a 93, you can also use a 4X4 93-up unit, and add a wire to the 10-pin to trick it into thinking it is in 4wheel drive at all times. I did this in my AWD Blazer, and AFAIK it is still working 15+ years later.
I have some modules here, Paul. You've never asked. I know your Typhoon needs a complete module, but I thought we had talked about this. The 93 system isn't worth saving. The 91-92 4 sensor system is under certain conditions. The most fussy part about adding rear sensors are finding the tone-wheel axles. DesertSy had/has ABS with its 4 wheel discs. I hardly ever triggered the ABS in that truck, but when I did it did diminish the brake performance. Unless you're spending a lot of time driving in snow, I don't think any of the ABS systems are beneficial, other than originality. Which you don't care about.
Sorry about the threadjack Dave.
No problem Dave, as always your input is very informative :)
