syty firing order
AlaskaTy
I'm a little curious as to what the correct firing order for our trucks is. I have been to whitetyphoon.com (richard Lee's site) and for some reason he has his distributor rotated clockwise 30* or so. should the #6 plug be in the 6 o'clock position? That would put the #3 plug in the 12 o'clock position. If I'm wrong could someone please clear this up for me. Thanks
Jason
jwaller
Evil Genius/SyTy Guru
Re: syty firing order
1-6-5-4-3-2 starting from the first post on the cap clockwise from the holdown screw on the drivers side.
AlaskaTy
Will this put the #6 plug in the 6 o'clock position? When I tried this a while ago it didn't work, and when I rotated all the plugs one post clockwise (#6 plug in the 8 o'clock position) it ran really rich and would shake a lot, but it would run. Now I can't even start my truck, it won't fire either way.
ghettosled
SYTY SUPERSTORE
its probably b/c your distributor is a tooth off. As long as your firing order is correct and your timing is sync'd up right it doesnt make a bit of difference. Just gets confusing if you change the wires, and never paid attention to the way they originally came off. Same deal as if you put the distributor in 180deg off. You can switch around the plug wires, and make it run just fine without removing the distributor..
If it bothers you, rotate the motor to tdc on the compression stroke pull the distributor and line up the oil pump drive so it will line up with the rotor pointing #1 in the new position.. Then drop back in the distributor so the flat portion of the cap points towards the driver..
