t-case fliud question
J_SULLIVAN
A&P slave monkey
SYN.... I use it my Sy and my Z-71... Mobile 1 or Castrol. Use Synthetic in the rearend too but you'll run into difference's on this topic, I promise.
Captain Morgan
Moderated User
yep, got that right.
I use standard Dextron III :D Whatever goes in the trans goes on the T Case when done. No need to buy tons of different stuff, keepin it simple is key IMO.
Beavis
Still plays with trucks
Thats kinda what I was thinking but not to sure, I did search but after the 420 results still no answerv on the question so thanks, I will go get some standard good ATF.
Mikes93Ty
i think the dealer screwed up
Just checked my fluids and lubed the front end on my Ty the other day and the transfer case has GL-5 gear oil in it, whats up with that? This the first I checked since buying it from GM dealer that said they replaced all fluids and did a complete tuneup. So I figured I'd ask the real pros on what fluid to put in it.
Mikes93Ty
Oh yeh I forgot to mention my Chilton's manual says some models use ATF and some use GL-5 didn't know for sure.
SyTyJedi
Jedi Council
I use Amsoil High Temp ATF in the trans and transfercase. Truck felt much 'smoother' after the change under all conditions. IMO - Amsoil is some of the best stuff out there.
Lynn D. Brown
Driveline fluids
Driveline fluids
ATF and GL-5 R totally different fluids, so no way U use them in the same service. GL-5 is extra heavy rear end fluid, something like 90-120 wt - even heavier that normal axle lube. ATF is thinner than motor oil.
U should never put GL-5 in the T-Case, or ATF in the rear.
skata
yeah, some t-cases use gear fluid. it's usually the older t-cases that use gears instead of chains.
skata
Re: Driveline fluids
GL-5 is a performance spec, not a formulation. most gear fluids meet the GL-5 spec in all different weights.
if you have gear fluid in your t-case, i doubt it would cause any harm. if anything it would cause more drag.
