T-case parts supplier ?????
autoaddictions
I think I need a new viscous in my SY!! Its skipping the tires real bad on tight turns. Worse in reverse. Where can I get a viscous,seals.chain ect. I really dont want to buy a used one. You never know what your getting.
AutoVation
Re: T-case parts supplier ?????
Are you sure it's the case itself? I had the same symptoms when my front propshaft went bad. Especially making the turns while under light acceleration.
I would also expect it to be cheaper (and easier) to buy a used t-case. They are pretty strong and you 'should' be ok (definitely not the weak point in a SyTy driveline).
autoaddictions
I didnt think it could be the front prop. I have a good Dynotech shaft from my typhoon. I guess i could try that first. I had it on the lift it looked ok to me.
cloneman315
frank what did you find?.sure as shit i think mine is on the way out,went to turn around today in a parking lot and it felt like the 4wd on dry road,and the left front wheel started to chuck...
SloGN
9Sec Alky V6
The parts supplier that i have used for getting trans parts in WIT (whatever it takes) I think that they are based out of charlotte. There number is 1-800-940-0197.
cloneman315
i called them today they did have all the stuff,but it not cheap,does anyone have the best way to get these rebuilt?Or does anyone have a low mile clutch?i just hate to pull it apart and not rebuild it all.
Six-is-Enough
Use to do a little Boost
How much do they want for a new VC?
