Tach flutter @70 w/ultimate
Ty 1450
30psi on 93 oct (boom)
Went driving around this afternoon after installing ultimate last night. I got up to about 70 and noticed the pedal bouncing on my foot, by the time i looked up at the tach it was bouncing between 2-3k for about half a sec then went steady again. This happened a couple of times while i was trying to get home to park my baby, also had this weird feeling while i was driving at around 60, felt like the a pause in the speed (kinda like driving 40 or so and a big gust of wind hits you dead on pushes you back, but your still going the same speed). When i got home i popped the hood to check to see if any of the plug wires where touching and all seemed well, except for the first time since i've had my ty the engine was actually pinging.
Possible problems im thinking of
1. Another bad F'ing taylor wire
2. Bad batch of gas - went out to look at a sy for a friend and ran a dm on the way out there, seem to run good just needed to raise the fuel pressure a bit to get some of the knock out. While we where out there i refilled my tank from some po-dunk gas station.
Thats all i can think of any help would be greatful. I plan on running some 104 to see if that helps any, but i cant run a dm till Patrick gets back in town this weekend some time.
smeagol
Tach flutter has proven to be ignition in 100% of my experiences.
That's all i can really say about that.
CLONE
I've seen stock chips not piggybacked properly cause the symptoms you described. Might want to double check the ultimate installation.
Ty 1450
Thanks i'll check the install again...and i thought about ignition when i had the tach flutter, just didnt think i would have another bad wire this would be #3 out of the set i bought. Guess i'll do a search and try a differnt brand of plug wires. Thanks for the tips guys.
Ty 1450
Well cant mess with it till tommorow, but atleast i can sleep a little better with it in sec mode, stearing column lock, alarm and ohh its in the garage also :D
Stangbeater
How bout it?
Most defently ignition. Could be not properly seated chip. Both of which I have experienced first hand. The tach flutter I had, was from the Holly wires with the alum. shields arching to the exhaust man.
Ty 1450
Finally had time today to look at the ty. Reseated ultimate then went to the gas station and filled up. The tach flutter is gone now, so im guessing it was a combination of bad gas and maybe the ultimated seated wrong. Thanks for the tips
CLONE
Just the ultimate seated wrong would be my guess. I hear that you had some trouble with the install anyways.
