Taking a poll on brakes
bkstg1
What kind of responce do you think a high quality brake upgrade kit that would be suitable for race use or performance street use?. I work for a company that is looking into developing new products. We can build and design anything.Tell me what your ideas of a great brake kit are and whats important.
Thanks.
Jim
'JustDreamin'
Dream: 6LV8 Turbo Bravada
Re: Taking a poll on brakes
Value. The performance / dollar spent is tough to compete with C5 brake conversions, like that offered by CBR. The braking ability offered vs. the cost is tough to beat. They only use 12.8" rotors, so that would be an area that could improve (maybe 13", 13.5", or 14" like on the CTS-V), but much bigger and the rotational inertia you gain starts to be a big deal, especially since you typically now need to run an 18" wheel, and that hurts performance too (which most people don't realize or consider).
Readily available parts (anywhere in the US). Again, C5 stuff is hard to beat. You can pick up a rotor, caliper, or set of pads at almost any Napa, Autozone, Reilly's or GM dealer virtually anywhere in the country. Baer and Wilwood have a tough time beating that fact, and that's important if all of a sudden one of your fancy bling bling drilled rotors develops a crack and becomes a 3pc rotor while you're on a road trip 400 miles from home.
Wide selection of available pad compounds. Again, C5 stuff is hard to beat. Lots of pad choices, from cheap replacements that don't dust to $200+ a set full race pads that dust like mad and require race slicks to avoid wheel lockup. And a wide selection of vendors, like Hawk, Carbotech, PFC, etc. is always desirable.
Easy wheel fitments. The C5 stuff isn't the best here. The offset in the rotor is pretty minimal, which means that you have to have a 17" wheel & even some of them don't fit because of caliper interference. It would be good to know exactly what fits and what doesn't. And keep wheel sizes to an absolute minimum. If you can run 16" wheels and 14" rotors, then you're really good (but I find that unlikely.
Ability to get non-drilled non-slotted rotors for street / track use (I don't need bling, I want rotors that last, don't crack, and don't eat expensive brake pads). Last thing I want to do is to put a $200 set of drilled rotors on to go run a track event using aggressive pads and eat the rotors up & put so much heat in them that they crack. 2pc rotors are nice and all, but you've got to have workable choices. For those who have to have bling, make drilled or slotted available.
Bling shouldn't be a decision making factor in choosing a braking system. Yes, it needs to look nice, but it MUST perform well. Personally, I would love to see brake dyno testing results simulating real world stopping. Simulate the tire to road interface, so you can take it out as a variable. Simulate a 3700lb car stopping with an 80 / 20 brake bias. Provide air at a specific temperature, but not forced cooling (to take it out as a variable). Do 4 stops back to back 60 to 0 (or 100 to 50) with x time to accelerate back to 60 (or 100). Afterwards, spin the rotors at 30mph for 30 seconds, stop (not using the brake) and take a temperature reading of the rotor, pads, calipers, and anything else that would be useful. How hot are they. What is the braking distance? Compare new setups to other available setups. Provide documentation & potentially independent verification. If your system is better, Prove It!
Easy installation. Try to minimize potential cutting, hacking, or chopping on the spindle if possible. Provide the installation hardware. Provide new stainless steel & rubber / braided SS brake lines. Make sure that if you need to adjust steering stops or whatever to prevent caliper or rotor contact, that you provide the hardware.
Provide good, easy to follow directions with high quality pictures. Make sure they ship with every package. Make them available online. Make tech support readily available through some means.
Make sure that the system is compatible with the factory installed ABS systems. If you don't, all kinds of potentially bad things might happen, including your company being sued for offering equipment that isn't compatible with the factory hardware and contributed to an accident. Your company might have a disclaimer that says it won't work, be warned, but Jurys don't seem to read warning labels (think about the person who spilled hot McDonalds coffee in their lap & sued and won big money if you don't believe me).
High quality parts with corrosion resistance is another thing that often goes overlooked. Often times, there isn't much you can do for the rotor. But the rest of the parts need to be as impervious to road salt spray, dirt, water, and grime as possible. Everyone likes a good looking set of brakes in a set of big open wheels, so make it easy for the parts to stay looking good.
Thats all the things that come to mind, I'm sure there are other things though.
'JustDreamin'
jbone
What he said. :tup:
Especially lightweight, and be able to fit w/ stock size wheels.
HighPerformanceTrucks
Lift & Shift Specialist
Thanks.
Jim
What do you mean by racing? Drag racing would require a lot less rotor and caliper than road racing. The repeated hard stopping during road racing puts a lot of heat into the caliper and rotor, so you need a setup that can deal with the heat.
bkstg1
I 'm asking about road race use.I have a Typhoon that I plan on doing some sort of brake upgrade to,though I'm not that confident about using stock style brakes as an upgrade.I figure that if you are going to go through the trouble of ripping apart you truck you or I are going to use stuff that will more than handle your needs.I don't want to use something that is "good enough".As your ability to push the vehicle harder progresses I would think you would want brakes on there that do not become your limiting factor.I realise weight is an issue,use of stock wheels,and cost are a factor.We are not in the practice of developing products or components that are deemed acceptable for a narrow margin,ie..good enough for what your are telling me but if you do this.....We have to build and design for extremes.We build components for the M1 tanks and grenade launchers and the locomotive industry.Parts such as links,idlers,brakes etc. If we produce something the chances are it will be very high end and durable.
