Need some help fellas. Just trying to separate the compressor side and center from the exhaust side. Any suggestions would be much appreciated. This one's being a bit stubborn.
heat it up with a torch then try to remove the bolts, don't forget the exhaust side's used to quite a bit of heat. You may have to go through a few cycles to get it there, but with a few cycles it'll probably break loose.
although difficult to explain, I made a sort of A frame with 2 2x4's with the point of the A being the 2x4's sitting under the compressor housing. The turbo hanging below that.
Then I beat down on the exhaust housing while man #2 held onto the whole thing.
