Tan wire effect
This is gonna be long, so here goes...
When I unplug the tan wire, to set timing at 0 degrees, what exactly happens?
I thought that timing should stay at or near 0 no matter what the rpms with it unplugged.
When the Ty is cold with the timing light set up, I start it up with the wire unplugged. It idles pretty high for 30 seconds with about 17 degrees of timing. Then it comes down to 600~rpm and the timing shows 0 degrees. I can then rev it up and timing will jump to 30-40 degrees. Is this normal?
Is my MSD distributor's ignition module screwed up, or maybe the reluctor? I have unplugged my 7AL-2 and HVC coil and put the stock coil back on. Still have something weird going on where more than 1/4 throttle results in a retard like state. It starts popping like a PRO 5.0 car on the line and boost comes way up. With the tan wire unplugged it idles like shit of course, but jumps right up and runs alot better with 1/2 throttle. Still isn't near perfect but is much better than plugged in.
I have a stock distributor with a bad ignition module to try if it might be the MSD reluctor. I hate to swap it in with the MSD module, just to have nothing happen if it was the module anyways. I guess I need Datamaster so I can check timing with the tan wire plugged in and match it with the Snap-On light.
Is there anyway a chrome timing pointer for a SBC is in the wrong location for a V6? Is there anyway a Fluidamper balancer can be off on its etched timing marks?
myclone
Re: Tan wire effect
Yes. SBCs use a couple of different pointer locations depending on the year and there is a distinct possibility that the chrome timing cover has the pointer in the wrong location. If it were me I would verify TDC on #1 with a piston stop to find out if the pointer is correct. If its not then that would prolly explain the popping youre getting.
Ive never seen a fluidampers timing marks off more than a degree or less and IMO that was tolerance stack from all the components. I guess it could happen but Ive never seen it.
As for why the timing is jumping around that far... I dunno right off. Need coffee before I think it over.
turbodog
lSyclonel said:
thats normal, the distributer has a mechanical advance in it. thats y the pointer jumps around.
Hmmm... are you sure? That does not match my recollection from having mine apart. The parts diagram shows no mechanical advance mechanism.
Maybe I have the wrong one? but shows all 91-93 4.3 to be the same...
turbodog
Here's what the parts book shows for our distributor, which matches my recollection:
and heres a block diagram I found of the ignition module (it's for a TPI V8, but I think it's the same as ours):
I don't see a means of advancing spark in either (with bypass wire disconnected) .... so not sure if your changing timing is normal or not.
OK, so can anybody confirm the operation of unplugging the tan wire on a stock SyTy and on a MSD 8367 equipped SyTy?
I just wanna know if the MSD distributor/ignition module is at fault, or if it's a bad BIN.
lSyclonel
im sorry guys, I worded it wrong, try looking into the module to see it if has its advancements, i was told once the it can adv. timing up to 15 degress on its own.(with the wire unpluged) but never confermed it.
