Re: Taurus fan mounting?
I have one mounted on my S10, and it's held on with a bolt through the top of the radiator......Not the finned area, that top little lip you see when you have the shroud off......there was already a hole there, that matched up to a hole on the Taurus fan.....Put a small botl though it, and a small nut and lockwasher on the back, and I was set to go. I also drilled a small hole in the bottom corner of the shroud on each side. Ran a zip-tie through that, and through a small hole I drilled on the lower radiator "shelf" keeps it from flapping, and works like a champ.....been that way for 3+ years now, and hasn't come off even with some pretty serious loading while autocrossing.
