TB Coolant Hookup
jharrison
Has anyone utilized the coolant ports on the Sy Ty throttlebodies. I was wondering if it can be connected to the intercooler setup. I know several european vehicle manufacturers use TB cooling, and since ours has the inlet and outlet orifices for it, it seems kind of a waste to not use it.
NecroWolf
lost marbles member
Re: TB Coolant Hookup
its a thought but i would think the water would have to be pretty cool to do anything
Loeryder
it was designed to WARM the TB in colder climates.
the port size is much smaller than the desired IC hoses so if you were to do it I would not suggest making it in series with the IC or you will reduce the flow to the IC.
FxsX24
94 S10 to be lowered/v8
or make a seperate one, but i think it may be hard to make it look good
do you use your heater/ac?????
could possible use the heater core with a fan blowing on it system with a pump and small tank (not sure if the heater core will work though since it is not really cooler )
Woo ho, just what we need, more hoses and pumps under the hood! :rotf: JK of course, build what you want. But, as mentioned, I think they were heat, not "cooling."
FxsX24
it sounded better when i first thought of it, then i figured i should post it anyways,
jharrison
I have to ask, why heat? Do the butterflies freeze shut or stick in cold weather? I just can't wrap my head around going from a "cooled" intake charge to a "warmed" TB, but then again GM is know for "parts bin building". Maybe thats why their not connected on our trucks in the first place, cause like you said it's for warming. I was just reading the Syclone repair manuals and came across the "coolant" ports as they were labeled, and as usual thoughts of squeezing out a few more ponies raced through my head.
wheels
it was there to prevent throttle blade icing on vettes. something to do with humidity and pressure drops.
