Slyclone
Well-known member
So a while back I purchase a larger throttle body. I was not sure what I was trying to accomplish besides spending money. The TB is not even SY-TY .
I went the extra distance and acquired a linkage (RPM) hoping my ideas would all come together. Since I started this little project on getting more air into the engine I realise It will take a lot more than I expected.
I ran into a issue Not knowing they laser weld or spot weld the lower knub on. It really looks like a spot style weld which is pressed and mushroomed. I thought about drilling the item out here at home on the work bench, but hesitated because I felt it was not the right approach. all the components are really close and can be damaged easy. I even have a air grinder which accepts "2 inch cookies" 3M has a pretty agressive line up for these. I thought of wizzzin the small amount off and making it flush so I can just pull it out- That is also border line Butch The Hack-o style approach.
Really I am not sure why I just did not spend the money on a unit that would bolt right on.
I have these sky high ideas and not sure if they will ever take off. There is a cost to all this and its trial and error. You can see how I like to try and do-it-my self.
The bar is around 7.5 inches long. Everything is pressed on. This is non removable at this point. I broke everything down basically to each part. Where I am at is do I go any further with this and try to get the lower knub off. I am not sure if a end mill will extend down 7.5+ inches and be able to face this off. The way it would get dogged down or clamped makes me wonder if this is possible the way it needs a "stand off".
This has been sitting in a box since I got it and not sure if I should go any further or just bail out.
Thanks everyone.
Thanks everyone.
