TD06 20G/8cm2 Upgrade Question
Trizney
The place that sold the previous owner this turbo can get the larger exhaust housings. I was thinking of getting the 12cm2 exhaust housing, but I was wondering is that all I need to get? Will I need to change out the wheel on the exhaust end? He hasn't quoted me an exact price, but he said it should be in the 250 range. Is that a good price for an upgrade like this?
Trey
Ian Turgeon
Cascading Inspiration
you need to figure out if you have the tdo6h or stock tdo6 turbo with a 20g wheel ( i believe its converted as I havnt seen a syty tdo6h exhaust housing in 8cm)
I dont know if there is a bigger syty housing for the tdo6 then the 8cm. if there isnt you would be swapping to the tdo6h exh housings which has a larger diameter turbine. I dont know if that can be used in the non-h center section, so they may be upgrading to the tdo6h center section. 250 seem cheap for that... especially if it includes the 12cm housing.
need to make sure hes not thinking in eclipse/talon housings as they use different ones.
Trizney
It is a TD06H/20G. The previous owner got it from www.majesticturbo.com and they list the TD06H as the only upgrade they sell for the Sy/Ty application.
So to go from an 8cm2 to a 12cm2, I need the housing and the wheel? TIA
Trey
jwaller
Evil Genius/SyTy Guru
the center section is the same for the H and non H turbine wheels. but if you change that you will have to have the cartridge rebalanced.
if it came from majectic then I bet you already have a 14cm exhaust housing. thats the only way it's sold retail and a 14 is as big as mitsu gets. which is plenty big. my T76 is running throught a 14cm. and is good for some high to mid 10's.
Trizney
Would there be any markings on the turbo to identify if it is 8cm2/10/12/14? When I called him, he said it was a 8cm2, maybe he thought I was talking about a DSM. I will need to call him again on Monday since he hasn't called me back. On Majestic's website, it says 400HP Stage 1. Wouldn't the 20G/14cm2 be rated for more then that? Ahhhhh, the joy of not knowing what you have.
Trey
Ian Turgeon
post up whatever numbers you can see on the exhaust housing.
(didnt realize the h and non h use the same center, thnx waller)
the markings as to what size it is are on the inside of the inlet for the turbine housing, I might be able to compare numbers on the outside of the housing to give you a good idea (have a 12 and 14 here)
more waller questions... is there an 8cm for the H? are our mitsu's ballanced as a unit or as individual parts and bolted together?
Matthew Little
20g
20g
there are 8cm2-14cm2 housings. The 8-10 need to be machine to fit the 20g wheel,but the 12-14 are a bolt on. I see people saying the 8-10-12 are hard to find. Robert Blouch in PA is a mitsu turbo dealer and said they are in stock. I have a 14cm on mine, but I am going to a 8cm to get my low end back. I have his number at work I will have to get it. The shop is Robert Blouch turbochargers.
Ian Turgeon
so I take it the 8cm non h housing is machined to fit the h turbine wheel from what your saying.
jwaller
the 8cm is not offered in a H size. but you can machine it to fit. I've never seen it done bc the thing is so small to begin with and then you cram in a larger turbine wheel. there isnt much room left for anything.
the turbine housing size is noramlly stamped on the inside of the housing right where it bolts to the header flange.
Trizney
Damn, so I need to take the turbo off to see exactly what I have. I am going to fire the thing up today for the first time since the motor died. If it fires up, I will will pull the turbo off tomorrow. If it doesn't, I will pull it off today and see what it says. Thanks for all the good info guys.
Trey
Matthew Little
20g
20g
Yeah the 8 and 10 are for the 17c,but they said it's no big deal to do the machining. They said it would be around 120.00 for doing it.
Mario65
Hotrodicus Supersonicus
How about posting some prices on the 20g/10cm I think that would be an awesome match. I would get one if the price is right. A little GP maybe?
Trizney
On the exhaust housing, this is what I see
(Mitsu Logo) 79 - 14300 0(with a little line under it)2
DUCI 9I
On everything but the 43, it is raised and original to the exhaust casting. Where the 43 is, it is shaved down and imprinted into the cast. Lemme know what yall think.
That is on the exhaust housing right next to the four bolts. I called majestic turbo and they said it would be on the outside, not the inside. Also, you would think these people would keep records on a computer about who they sold what. But nope.
Trey
Ian Turgeon
the 79-14300 matches my 14cm
non H turbine 8cm: 79-12100
H turbine 12cm: 79-11300
H turbine 14cm: 79-14300
Trizney
Alrighty then. So this means longer spool times, but once it gets spooled, more higher RPM power. What is the max CFM with a 20G/14cm2? Is it still 650cfm?
Trey
Ian Turgeon
yea, as far as I know the exhaust housing/turbine doesnt effect the compressor map. The bigger housings basically give you less restriction when your ramming that 650 down its throat.
I wouldnt even attempt that 14cm on the stock converter. Your either gonna need a converter, or to find a different exhaust housing.
