TDC question
spooldup
Super Member
Stupid question but i don't know the answer. While looking for tdc how do you know when you are on a compression stroke or an exhaust stroke?
SY#2910
Banned
Re: TDC question
Take out #1 spark plug (Front towards grill on the drivers side) and put your finger over the hole while turning over the engine a little at a time. You will feel it pushing air out while it is approching (0) on the timing mark.
spooldup
Super Member
makes sense so i would imagine on the exhaust stroke you don't feel air when it's coming back up right?
kentuc
Remove distributor cap and see if rotor is coming up on #1 cylinder.This is used for tuning only.
#2875
built, not bought
when attempting to start, mine wouldn't do shit but drain the battery when the rotor was 180 out. that's how i knew and that's the hard way. i had a 350 180 out and it started and ran.[/b]
