TDC tango
IGottaSy
Here is another thing I was fiddling with today as I was having a bit of trouble lining it all up for confirmed TDC. Decided to confirm rotor was firing right on #1 plug.
I was able to get rid of a lot of timing related knock. Somehow, ended of out of whack. Hope this is somewhat helpful.
https://youtu.be/efxX0d8Aw7M
IGottaSy
Re: TDC tango
Just thought I'd share this,
I made a little TDC tool with some old stuff lying around. It consists of the following :
1. Spark plug anti foul fitting
2. Old vacuum hose, 1/8" or slightly larger
3. Old pen - need the spring inside
4. Electrical tape
5. Old cable from cruise control or similar
Put it all together...
[/URL][/IMG]
This indicates the position of the piston very accurately, for me anyway. I used on old cable and old rubber hose because they are flexible and can be used in-car without too much drama. The pen spring is just the right size for a dished piston. May not work on high compression pieces. That tiny washer came in the pen as well. I got lucky. Length cut to suit. What really matters is what goes inside the spark plug hole. A longer spring would work a bit better. This Spring Was About 1" long
https://youtu.be/C-KeQXYBpOQ
