Te 44 Vs Te54
I am about to upgrade the turbo in my truck and would like to know how big to go. Truck has stock motor and heads trans will have a 3000-3200 converter in it aand will be upgrading to 50# injectors. Right now the truck has a te44 on it and I would like to go bigger so do you guys think a te54 is to much for the stock motor. Also is there going to be much differance in power between the two.
Thanks
ghettosled
SYTY SUPERSTORE
with that converter i would use a 60-1 P trim. the 54 is a 57mm P trim, and i think a 52 is a 57mm stg V if memory serves me correctly. The 60-1 in a t04b housing works very well at 15-20psi which is where most of you guys boost on the street.
