TE44 or PTE 51
TE44 or PTE 51
  • Total voters
    1
kwick6
Trying to decide which turbo I should run on the typhoon.
I have them both here. I have a PTE housing to put on the TE44, so I can run the PTE DP.
What is a better quality turbo? The garrett is water and oil cooled, where the PTE is just oil cooled.
I could use either one, just wanted to get some opinions first.
I don't think either would be a big enough turbo, after an engine rebuild.....so I'm just talking about on the stock engine. TC is 2800, so thats not a problem.
What injectors you got? Go the 44 if stock 51 if 50's
Ive got a 44 and stock injectors, converter Works good. But the injectors are maxed.
Vaders Sy
Having had the 44 I would go with that since you don't have big enough injectors. If your going to bigger injectors go with the 51. My sig shows my time with the TE44 from PTE.
kwick6
I guess I could do the 50lb injectors, since I'm going to have an ultimate from the sy. Not too mention the bling polished look of the 51 and top portion of the DP.
Can't wait to ditch that stock downpipe.
I may have a te44 up for sale soon with a PTE exh housing, and a top portion of the DP that has been jethot coated. It would require the rest of the DP to be fabbed up, but I would be willing to sell it for around $800.
kwick6
Ok, leaning towards the 51. What plugs do I get for the water lines? I need to get those, if anyone has a pic or size of what I need that would be helpful.
kwick6
thanks jimmy.
Should I get that from PTE? , or does anyone know the size?
Is there another plug underneath where the coolant drains? same size?
HighPerformanceTrucks
Lift & Shift Specialist
Depends on what you are going to do mostly with your truck. If drag racing is your thing, I'd recommend the PT-51 if you have the fuel. If autocross or track days or daily driving is your hobby, I'd stick with the TE-44. Then again the new ball bearing turbos give you some room to move up in size with less turbo lag. Since, I drive mostly on the street w/ occassional auto x and a bit of drag racing, I opted for the TE-44 with the wet center section.
SeattleSy#1255
Category 5 Conservative
Read tooky's post about his 51...believe he is running 11's on stock injects....however i'm sure he is pushing them, as well as the engine...he even says it...but it is possible with stock injects. Scan tool!
kwick6
51 is on the truck.
If anyone has any questions on how to remove a stock DP, PM me and I'll give you the step by step instructions. :lol:
