Temp. guage install?
1madgumby
1st. can the sensor on the drivers side block be removed? 2nd. If so IM going to install the Man. temp. guage there. Or does it have to go were the sensor is on the lower intake & the one on the block has to stay in the block? intalling ATR headers & it is in the way..
Aj.
ghettosled
SYTY SUPERSTORE
Re: Temp. guage install?
there are two water temp gauges.. one on the intake manifold the other on the driver side cylinder head. The one in the head is for the gauge cluster, the one in the intake is for the ecu.
You can put the mechanical water temp gauge off the block with a 1/4" npt adaptor like this:
dont know what the correct PN is but i believe it is 1/4" npt to 5/8-16. An electric sender is a bit easier to install.
