Re: Temperature question
Heres my situation, my truck had bad throttle response and bad idle because the truck wouldnt warm up enough to reset the TPS sensor with the 160, but when i popped in somthing higher it eventually warmed up more if not right at the 1/4 mark and reset the sensor to make the truck run better,now that it is reset , then wouldnt switching back to a 160 be bad? I drive the truck probally about 30 min at most around town between places before stopping somewhere? It is summer of course and its hot, but it never reaches the 1/4 mark. So wouldnt it be better to run a higher stat than 160 if i just drive it around town? And if I drive long trips daily to run a 160? You guys mention that it dosent get over the 1/4 mark but isnt that bad to not warm up or does it get to the mark but not much over because with the higher stats and smaller trips it does that? and is not running a 160 for short trips loosing performance?
And Im running a 195 now and it warms up a tad over perfect, if 160 is too low for shorter trips than ill by a 180
thanks
