Maxtor
Re: th400 vs 4l80e Give me some info
If it was truly built well it will definitely survive 600-700hp and make 10sec passes. My Rossler built 700 has been making 10 sec passes for almost six years now without an issue. The question is how long will it last, the 400/4L80E are definitely stronger but the myths about 700 transmissions not being able to handle bigger HP just aren't true (obviously to a point).
Another thing to consider about the 400 is your goal for trap speed in the 1/4 mile. You can make it but typically that means playing around with different gear sets and having a higher revving engine. I can't make it through the 1/4 without OD with a 6k RPM redline. The Hoover's ran a 400, I seem to recall a conversation with Jim at one point where he said they were hitting their 7k RPM rev limiter before the end of the track. If you're only planning on running it in the 1/8 mile no problem.
Good luck, consider everything carefully before jumping in.
But the 700r4 only has 22 miles on it and was built to go. And has all the good parts I jut know it won't survie 600 or 700 hp and make a 10sec passes
