The age old question......Vortecs
  • RPM
    Votes: 8 47.1%
  • Jerry McCoy
    Votes: 0 0.0%
  • ATR
    Votes: 0 0.0%
  • Look else where
    Votes: 9 52.9%
  • Total voters
    17
  • Poll closed .
Syonara
Its that time--I am looking for a complete pr. of Vortecs w/the intake modded to bolt up. Ive talk to Jerry Mc. and RPM and TurboTime. Is there any feedback on their work? Port/Polish work? Anyone ever use a dif. valve sizes-other than 202/160's? I have a 412cam ill be using and 1.5 rockers. I hate to make a post that im sure people have had questons about... just wanted a current oppion on a $2k-2500.00 question.
Thanx
Michael Ny
Sy#0919
a.)RPM
b.)JerryMcCoy
c.)ATR
d.)look else where
93ty475
Re: The age old question......Vortecs
I've never understood these "stage" references, but I pulled off my conversion locally....I dealt with three different shops....One for the heads, one for the intake welding and one for resurfacing the intake....we went with the 2.02's and no porting.....I spent under a grand on this including parts and labor (not install labor), plus running around....what took the longest were the heads...All the head builder needed from me was the cam card, rockers, vortecs and the lower intake....when I told him what I needed done, he said this was a strange request and just shook his head....you should have seen/heard his reaction when I let him drive my truck after getting it back together :cool: .....I'd probably go with one of the above mentioned deals if money was no object to me and I needed it now....our vendors probably go throught the trouble of stocking these components....the way I did this took quite a while....I sort of understand why these guys charge what they do for this for this....there's alot of running around involved....
tbauer03
TRBOBOX
i got my heads off a local guy then had my intake modded by waller and then had the machine shop do the heads and port match them to the intake. oh and i went with 202/160
crashing_sux
Blow Me?
The Stage reference is actually a time measurement.
Stage 1 = You'll be broke for a month.
Stage 2 = You'll be broke for six months.
Stage 3 = You'll be broke for a year. If you were married, don't count on it lasting.
Stage 4 = You won the lottery.
93ty475
:rotf: :rotf:
Syonara
So RPM's it is. But heres a question, has anyone used the 415CAM?? I have the 412CAM and plan on using it.......but curious of peoples thoughts.
crashing_sux
Blow Me?
Phil's using it, then again he's slow as hell so you may want to avoid it unless you want to be stuck in the low 10's.
100in6
100in6
if you do vortecs don't go goofy on porting. if they get hot they will tend to crack if you do. also, i'm not so sure you need all that flow. also, mike renz used to have a guy who matched up the intakes and did a nice job i hear. try to find someone not too far from where you live in case you have problems. also, i think mike lee is still doing them. is jerry not doing syclone stuff anymore?
i had studs on my block and that made getting the heads off a real bitch.
