The EST or the ESC?????
imposters
Hi I had a post on last week about my truck.. It is reading a code 43.
I can get it to start BUT I have to have the gas pedal to the floor and it runs really rough...... The ecm fuse is ok and put a new knock senor in..
What could the problem be???????? I have removed all the wiring to the abs, ac and the heater is that a bad thing?????? Would the boost controller wireing have anything to do with this problem?
I would love to drive it someday. It has been a year and a half seens it ran.
Thanks if you can help in anyway........
thanks agian
Andy
sytyguy
Moderated User
The ESC system on our trucks is very simple......knock sensor sends signal to prom which interpretes it to ECM......ECM references it against bin data and sends adjustment (advance, retard, etc...) out to the ignition module.
I had a Jimmy that did the same thing. Turned out to be a faulty ECM. Might try to swap with a known good unit and see if that helps. Also, I had a code 43 that wouldn't go away in a Syclone once. The truck ran fine, but the code wouldn't go away. Swapped the distributor and all was fixed.
Have you verified TDC and checked timing?
HTHs
Hood
imposters
I can't check the timing what a timing light because it does not stay running. All the parts r new on the truck. what is the list of thing that it could be??????? I will buy new one if i have to...
I am not setting out this summer what no truck...............
Thanks Andy
sytyguy
Moderated User
Well, do some prelimary checking first. When you cut the key on does the CEL flash once and then stay on? If not, it may definitely be a bad ECM or ground (the main ECM grounds are the ones on the T-Stat housing). Even still, I've seen bad ECMs when the CEL acts properly.
I understand that this is frustrating (trust me, we've all been down this type of road), but you can't rule anything out with these trucks. Go back over your steps and make sure than everything is plugged in, no chafed wires, no crossed plug wires, etc....
The best thing to do........get a local SyTyer with a good running truck and a generous personality to brind his truck over and just get to swapping things until you find the problem. Sounds archaic and redundant, but it works.
BTW, CEL = Check Engine Light
Hood
Tim Zapoluch
I had a problem similar to this on a 87 gmc pickup, with a '165 ecm. I fixed it by cleaning the ground connection on the gooseneck. the problem soon returned, so I re-located the ground to a better spot. I don't think the intake manifold is the best place to ground the ecm, seeing as the ground path has to go through the bolts, which are through a dissimilar metal junction (iron to aluminum). I grounded the ecm to the block and all is fine, for over a year now.
Good luck!
Tim
