SpoolingTurbo6
Using White typhoons diagram for firing order and wire placement, Wired up the Sy with the 98 Vortec. Using my old distributor from 91Sy
The motor wants to pop like its out of time BAD!
Backfired up threw the intake once and that was when I then pulled the distributor out checked for TDC on the Rockers,Piston,Crank...... Everything tells me I'm up on #1 @ the compression stroke.
And rotor is pointed @ #1 on motor and cap.
everything I've found says that the 98 is the same firing order.
Also going to check the Ostrich to see if Batteries are dead <---will you loose the bin replacing Batteries?
TIA Guys :tup:
TIA Guys :tup:
