The Hardest....?
BillC
Re: The Hardest....?
HotRudyRod said:
Whats the hardest you can push a stock engine? Durability aside...
Thanks.
If it's just sitting on the ground, I can probably push a stock engine about 15 or 20 feet without resting (farther if I roll it). Probably wouldn't do much for its durability, though. If it's on an engine stand with wheels, I can push it all day long and not hurt the durability. :p
ed hess
race or get outta the way
Thanks.
sinc eyou did say durability aside:
most dont know and wont beleive that tom ferrick had been using a stock block bottom end when he 1st ran high 9's. of course it developed a knock ....
ya know its probably a whole ot cheaper to just buy a handfull of bottom ends from the junk yard and run em till they break..... then again this doenst take into account your labor time redoin it ever month or 2....
ed
nick041881
i think durability directly affects how hard you can push a stock motor. im sure with good gas a stocker could handle a few 26 psi runs before it explodes. who knows? but you can only push it as hard as the motor can handle=durability.
ghettosled
SYTY SUPERSTORE
ed hess said:
most dont know and wont beleive that tom ferrick had been using a stock block bottom end when he 1st ran high 9's. of course it developed a knock ....[/quote]
I definately find this hard to believe, if you mean bone stock shortblock. If you mean stock engine block, then yeh thats well believeable seen as how most of you guys in the 10s (non bowtie) could be running high 9s if the trucks were lighter and 2wd.. Dean Oller made some high 10 sec passes with a junkyard longblock in his 2wd ty. I would have to agree that Phillip Long has the most impressive stock motor times.
ed hess
i mean the whole bottom end... block, crank, pistons, rods..... like i said, it later devoloped a knock!.... kind of expected :D
HotRudyRod
BillC said:
Thanks.
Pretty funny but i said how hard not how far :splat:
Would race gas and alki injection both help to boost it (stock everything, injectors, turbo, i cooler, etc) to 25lbs and keep the knock at bay?
Thanks.
bezerk
HotRudyRod said:
BillC said:
Thanks.
Thanks.
that's why every body throws money at these things....
if it was all that simple.....
BillC
HotRudyRod said:
BillC said:
Thanks.
Okay, you try pushing an engine along the ground, and then you'll see just how hard it is! :p
HotRudyRod
BillC said:
HotRudyRod said:
BillC said:
Thanks.
Ok, sounds to me like YOU already tried, lol.
sy538
I heard the same thing about lee howie, broke his built engine and ran 10s for a day with a junkyard (not low compression/strong main caps) engine.
