The new Calif Smog Test.
SY2455
70's Veteran
Will I got the truck tested with the old cat again and the truck passed. They still do the Idle and 2500 rpm test and visual. They added a new test that takes about 20 min longer because of the gas tank test. In this test they clamp the gas tank to the fuel vapor canister line, near the canister, then the gas tank is pressure test at 2.5 - 3 psig with nitrogen to check for leaks. The tank must hold this pressure for 20 min. If a leak is found you have to get it fix ASAP or fail the entire test. :tdown:
Mephisto
These trucks are cursed
Re: The new Calif Smog Test.
if you put less than 3000 miles on your car every year, you shouldn't even need to get it smogged... but thats just my :2cents:
I'm sure Jay Leno doesn't drive every single car in his collection but it just seems ridiculous for him to have to smog all the cars he has registered... especially when he probably doesn't even put 500 miles a year on them. there's gotta be some way around that.
chelo
filthy sy
I just got my landcruiser tested and yes they did pressure test the fuel tank but it took no where near 20 min. It took about 10 minutes extra.
Same here when I recently sold my old Bimmer. Extra 20.00 if I remember WITH my discount. :tdown: At least with cars I think we've long since reached the point of diminishing return.
Syclone'D916
Syclone Owner #2414
That's not good, I got till next year till deal with that Crap,I hope my smog guy is still there and can help my sy Pass.
SY2455
70's Veteran
There are 2 ways around it.
1. Every car must be made before 1975.
2. I have heard that if you have a Dealer License, you can get around it somehow.
chelo said:
certain counties in calif do not require smog.
Yup, in fact Sonoma County, where I live, is split. I'm moving the truck to the north end, out of the "Bay Area Air Quality Management District."
NJ93TY
All you cali people should move out here on the east coast. Maybe somewhere in Pa where they dont have emissions testing in some parts, you dont need a front plate and you are allowed to have tinted windows. Or how about michigan where they dont have inspection at all. :tup:
Mephisto
DaveP6999 said:
That's the most logical suggestion / opinion I've heard regarding this in a long time.
why thank you! i'd run for office but i'm sure having logical and rational thoughts automatically disqualifies you.
DaveP6999 said:
A good number of his cars are older than 1974 model year. These are exempt from bianual inspection in California.
i thought they did away with that a few years ago and all cars had to be smogged? err didn't they vote on it?
Mephisto
hmmmm.... i going to be passing through that area next month. What if i get a PO box up there and change my registration address? I'm sure the annual cost of the PO box would be cheaper than getting the smog test done, and i wouldn't even have to take my truck apart every other year.
I'm going to DMV anyway to get my change of address form, I'll check into the PO box thing. I've been wonderin' that myself.
chelo
filthy sy
It should work. I've seen the strangest things with licenses. I once used to work as a counter person and asked a guy if i could see his license. It was a California drivers license with a Reno Nevada address.
SY2455
70's Veteran
They did do away with it for vehicles that are 20 years old, But that wolf in sheep clothing overturn it. So as it stand now, all vehicles starting with 1976 must be tested every 2 years.
4C FED
Absolutum Dominium
They do, but only upon sale or transfer of the vehicle.
So once you have it registered at an address in that area you don't have to worry about it again. At least until they mandate enhanced testing statewide.
4C FED
Absolutum Dominium
DaveP6999 said:
Beginning April 1, 2005, the 30-year rolling exemption has been repealed. Instead, vehicles 1975 model-year and older will be exempt. Therefore, 1976 model-year and newer vehicles will continue to be subject to biennial inspection indefinitely.
Dave
Yes, we can thank the wonderful Governator for not vetoing this legislation.
SEMA lobbied heavily to have it defeated. http://www.semasan.com/main/main.aspx?id=61491
I sent my letter to the Gov. advocating it's demise.
He's nothing more than a useful idiot for the left.
You can look on the SEMA site for pending legislation in your area to make sure you can provide your say to your representatives. Please use it. http://www.sema.org/main/semaorghome.aspx?id=50721
All you Greenies out there can "SUCK IT!"
